I hope I'm not screwed
jonpno
Sep 11, 2007
39
well i tried to jailbreak my iPhone with the tutorial by chris716 and somewhere in the process got confused i think at the part after the oktoprep. so i installed oktoprep. after that it says to go back into iTunes an upgrade to 1.1.2. but there is no update or upgrade just restore or setup new iPhone. so i did the restore. long story short iTunes wont recognize my iPhone anymore. so i held the power and home and it came up in recovery mode in iTunes so i hit restore but it gives me an error 1604 i believe and it goes into the screen with the iTunes logo and the cable. so it wont let me restore. WTF! I NEED HELP!
Ooh. You should have asked before you Restored. There's another guide that clearly states that you cannot Restore at that point.
I'm not a jailbreaker, but I would suggest downloading iBrickr (assuming you are using a PC) and let it boot the phone. After that, you may be able to perform another update or Restore.
- John
jonpno
Sep 11, 2007
39
How do you start the restore process all over? I've tried to restore though and I can't. It gives me an error code 1604 then puts me back into recovery mode.
