I just got screwed by Customize 2.0
moze
Nov 9, 2007
Hi everyone,
So i was installing the vista perfection theme http://forums.everythingicafe.com/threads/vista-perfection-theme-awesome.23718/ and i then decided to installed customize since in that theme download package came some extras for customize. after installion, i notice my dock was gone and the status bar, and not only that, now all my icons are back to the old default icons and no matter what theme i put or do i cant change the icons, only the wallpaper will change, this is really annoying, anyone know a fix around this?
guest0320
Nov 11, 2007
728
Join the club, Customize just F'd my phone as well.
I have the eternal silver Apple
moze
Nov 9, 2007
wow...and now i just received a missed call and its not showing up in my recent call history..first time this happens..not sure if its due to customize but it never happened before i installed it. i guess this is a full restore
moze
Nov 9, 2007
Mines working fine and has been for awhile...should i uninstall it?
your call..if you haven't had problems with it it doenst guarentee you wont have any later.but i don't see why it should just create problems all the sudden. you might just be one of the lucky few!
xcissexc
Aug 9, 2007
501
That's why i use Modded Customize 1.21 (custom)
It works PERFECT !
my customize 2.0 actually works better than my customize 1.21(custom) did. my sounds from 1.21 never worked and then as soon as i installed 2.0 everything worked liked a charm
