i m in deep shi*
Oct 26, 2007
11
edit : k problem solved n bak to normal .
thx for yr help man...
KNK
Jul 22, 2007
2,391
Stevenson Ranch
some one here please help me n let me no wht i m doin wrong here ,
i was on 1.1.1 n tried to update it to 1.1.2.
the mistake i did was instead of update i did restore 1.1.2.
so my oktoprep didn't work n i had no choice but to downgrade it to 1.1.1.
now i m on 1.1.1 n the problem is tht everytime i click appsnapp from jailbreakme.com it brings me to main activation screen n in like 1 minute screen goes blank..
now i don't remember if thts how it suppose to b. i did set auto lock to never but it still does it whn i m on main screen n after 1 minute it goes blank.
i waited more thn 10 mins but no call so i couldnt jailbreak it.
someone please tell me whts wrong goin on here ?
please help me ppl
Which how to are you using so I know where you are?
Did you get to the good error 1015?
Chris.Carter770
Dec 25, 2007
99
When I jailbreak I use the *#301# method with adding the 2 urls and when you install the apptapp from the jailbreakme.com the phone should restart and when it comes back on slide to unlock and your installer will be there.
