I modded my iPhone for tethering. Now I have no visual voicemail
UFGator
Jul 17, 2007
227
Hi all. I modded my iPhone per the instructions at http://www.krillr.com/tag/tethering and now I have no visual voicemail. Tethering works great, but I really need my visual voicemail. Can anyone tell me how to undo everything to get back to normal?
Go to Settings > General > Reset and Reset Network Settings. This should fix it.
UFGator
Jul 17, 2007
227
Thanks Lincoln, but that didn't do it... Any other ideas?
shutter13
Jan 8, 2009
2,208
153
If you have a "cellular data network" tab under Settings>General>Network and there is a setting for voicemail...make sure the APN is acds.voicemail
UFGator
Jul 17, 2007
227
I don't have that option. Do you? How can someone else have that option and not me?
Thanks.
UFGator
Jul 17, 2007
227
Is there a way I can just load a new IPCC file and get my phone back to the way it was originally? It looks like there are other ways to get tethering. I just want to get my visual voicemail back.
Darkhova
Jun 29, 2009
52
New Jersey,USA
If you want the carrier file Visit this link http://bit.ly/UJiLP
Open iTunes Click on your iPhone...If your on PC Hold the Shift Key(Option Key on Mac) while you Press the Check for updates button then just locate and click on the file you just downloaded then it will give you the carrier Update
iStealth
Nov 5, 2007
421
Had this same problem and had to do a full restore and set up as new phone. AT&T couldn't figure it out
UFGator
Jul 17, 2007
227
You are THE MAN! This worked! I tried going to the web page per your previous entry and that did not work, but this one did. Thank you so much!
RPMSTL
Jun 22, 2009
251
Visit this link on your iPhone then just choose your Country then carrier and that will reload the Internet tethering.... http://help.benm.at/tethering.php
This works perfectly. I can tether USB and Bluetooth wonderfully. No VVM issues. XP and Vista both instantly recognized the network connection. Now I can get rid of my Sprint Aircard!
