i need a help! trying to update my jailbroken iPhone 1.0.2 ---->1.1.3
Oct 19, 2007
17
hello people..
i have jailbroken iPhone firmware 1.0.2...
now i wan to update to 1.1.3..but my biggest question is...
"Will itune re-lock and brick my iPhone when i update to 1.1.3?"""
how can i update?
i live in canada and i am not an At@T customer...
thanks
jae
Sep 29, 2007
348
If you are unlocked (not using AT&T as your carrier) then yes 1.1.3 will lock your phone as it will see an incorrect sim. If you want to experience a sense of a update you can always upgrade to 1.1.2 which has many more features than 1.0.2 and still use it unlocked by following this guide http://forums.everythingicafe.com/forums/iphone-jailbreak/go-from-unlocked-1-1-1-to-unlocked-1-1-2-a-18267.html.
It says you must be on 1.1.1 to go to 1.1.2. I am not an expert and do not know if you can do the same from 1.0.2 to 1.1.2 but ask there and they should help.
jjk454ss
Sep 27, 2007
45
What if he is not unlocked, just jaibroken? I have 1.1.2, jailbroken, and I am wondering the same thing. Mine is not unlocked though. Do I just do a restore to 1.1.1? Do I do anything special, or just restore with iTunes holding down ctrl or whatever it was that lets me choose the firmware of my computer?
seb481
Aug 3, 2007
774
San Diego
I am wondering the same here. I have a jailbroken (NOT unlocked) 1.1.2. Can i just go to iTunes and click restore?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
If you are just jailbroken you can just do a restore and you will be fine.
Are you on 7.6 iTunes, you can do a restore as well.
seb481
Aug 3, 2007
774
San Diego
Yes, i'm on iTunes 7.6.
I might just upgrade to 1.1.3, I can't wait to see this google maps thing
lucky8926
Jun 16, 2007
217
Central IL
I'm still an original 1.0.0. iPhone and haven't installed any updates on my phone or iTunes. If I decide to upgrade to 1.1.3. I should be ok doing a restore to 1.0.0. then installing the 1.1.3 on iTunes an my phone.....right?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Wow, you need this update, there is so much things fixed etc.
Just open iTunes, go to help, then click "check for Updates" this will then get the 7.6 iTunes. Run the software, reboot your cpu, then dock the phone, and click the check for update button of the summary panel.
lucky8926
Jun 16, 2007
217
Central IL
I've updated iTunes to 7.6, but none of the iPhone updates. I hadn't upgraded because none of the "new features" really excited me enough to lose my hacks. I know eventually it was able to be hacked with the new updates but it seemed like too much of a hassle to lose everything re-jailbreak and re-install all the 3rd party apps I already had... BUT with 1.1.3 it seems well worth it.
So I won't have to restore to 1.0.0. before upgrading to 1.1.3.?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Well now that is a diff situation, You did not say in your post that you were jailbroken, that is a diff story.
lucky8926
Jun 16, 2007
217
Central IL
Yep i'm jailbroken, I thought I mentioned that? Sorry... So would I be ok restoring to 1.0.0. first then downloading the 1.1.3. to iTunes then my iPhone?
jjk454ss
Sep 27, 2007
45
I just want to make sure I do this right. I need to do a RESTORE, then UPDATE. Right? I can't just update from a jailbroken 1.1.2? Can I RESTORE to 1.1.1, then UPDATE to 1.1.3? Or do I need to get 1.1.2 from somewhere? If so, where can I get it?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
It does not matter at what firmware you restore at, it will restore and wipe your apps out, and make your phone like original. So just do it at the 1.1.3
Anyway they will have a jailbreak solution for 1.1.3 within a week.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
You just need to do a restore.
what iTunes do you have right now? What ever it is the restore to that.
If you have the 7.6 iTunes then just dock the jailbroken phone and hit RESTORE do not hit update.
jjk454ss
Sep 27, 2007
45
So I can Restore right to 1.1.3? I was thinking I had to restore to an older version first.
xwtfbrendan
Dec 25, 2007
42
Connecticut, USA
Yep, I had a Jailbroken 1.1.2, I just hit restore + update + backup. Clean install, syncing music / photos now.
I have iTunes 7.5 BTW, if that matters.
jjk454ss
Sep 27, 2007
45
what do you mean by restore + update + backup? Are those options for doing a restore. Or different steps to take?
harshpshah
Aug 5, 2008
how do i upgrade unlocked iPhone 1.0.2 to 2.0?
I just exchanged my blackberry pearl with a friend who had unlocked iPhone running on 1.0.2 (i'm on t-mobile USA). I want to update the phone to preferrably 2.0, (or at the least 1.1.4). Can anyone here please tell me the steps? This is more or less the first time i'm even touching iPhone...so i'm bit nervous.
What i understand from here as well as other sites i have read, i need to perform a restore to 2.0 (which will lock my phone) using iTunes 7.6 and then use pwnage to unlock it? is this correct? will my phone work as a phone and will it access edge network if i do this?
Thanks....appreciate the help.
