I need a little help...
isal
Mar 22, 2009
136
Toronto
AdrianCubed
Jul 19, 2008
3,585
40
London or Miami
You have the latest iteration of the macbook, yet you are asking if you should trade it for the older version Macbook Pro + cash.
No. Keep your unibody. It has more technology, and features....also the 13inch unibody macbook is almost equivalent to the technology in that old 15inch macbook. The unibody has newer features, screen, and the processor speed isn't that different etc. The only difference is screen size, and unless you are heavily using graphic intensive applications then the 13inch should not matter. If you are just emailing, Safari, music, pictures the 13inches is perfectly fine.
Marianne
2,326
Massachusetts
marianneschultz.com
I agree with London. You have the most up-to-date MacBook Pro and there's no good reason to take a step backwards unless you really need that $400. Plus, yours is still under warranty. If his MacBook Pro needs any sort of repair in the near future, that $400 will go very quickly, and then some.
