i need help asap
St3ph3n
Jan 22, 2008
i was in the middle of chris716 guide to jailbreaking and i got to this part
"Once this is installed you will see installer on your home screen of your iPhone.. Click this and go and click all packages and scroll down till you see OKtoprep and click that and install it. A message will pop up saying you are ready to upgrade to 1.1.2.
At this point go back into iTunes and click upgrade and upgrade back to 1.1.2 this will take a lil bit for it to finish but just wait.."
but when i go back to iTunes it will only let me upgrade to 1.1.3 what should i do i don't want to mess up my phone
Goodlife08
Jan 23, 2008
53
i don't have the choice to pick shift update i can only click continue after bubbling "set up as new iPhone" or "Restore from backup"
someone please help
Busaholic
Oct 4, 2007
someone please help
While in iTunes, hold down the shift button on your keyboard then click the restore button in iTunes then locate the 1.1.2 file and click on it. Voila :cool:
