I need help jailbreaking my 1.1.2 iPhone!
seabase
Oct 16, 2007
I followed the steps on this site for upgrading and unlocking my iPhone, but when i come to run the jailbreaking programme and click on the windows bat file, there is a window in dos that opens and closes and nothing happens. Can anyone please help me.
Seabase
Thanks a lot!
6,683
50
You need to actually extract the contents of the ZIP file to another folder.
I did the same thing and was confused because I was looking at the files in the zip, and not from a regular folder. Once I put the files unzipped in a regular folder, it ran like a dream.
seabase
Oct 16, 2007
Thanks dude for all the help.
6,683
50
If you are getting that in iTunes, CLOSE it first. The launch the extracted windows.bat file. ( I would tell you to also go into the task manager and end iPod service and iPod helper as well, before launching the bat file.)
john jones
Nov 27, 2007
Unlock original 1.1.1 activated phone with new 1.1.2 update
Seabase
Thanks a lot!
I need to unlock my activated iPhone. It had the original 1.1.1 and i recently upgraded it to 1.1.2. Is this unlock possible ? I orignialy tried to unlock it before my upgrage with anysim 1.1. It said it was successful but never worked. I upgraded to 1.1.2 because i needed to restore it.....Please help
djf1530
Dec 4, 2007
I have tried it with iTunes closed and open
I have tried it with iTunes closed and open. Its the jailbreak software that is telling me "connect device"
6,683
50
Reboot your computer, and then try a different USB port. If that still doesn't help, try a different cable if you have one. I have had this problem with the BT dual dock. ended up using the stock cable in a different port.
iCreep
Nov 14, 2007
84
What also helps is if you extract everything in the zip folder into the actual C: drive under my computer. I had the same problem until I just extracted it into the C: drive when I was jailbreaking my 1.1.2 firmware.
iCreep.
