I need help with quickpwn please
H
Hayesimus
Guest
So i got a 2G 16gb iPhone on ebay that was already restored to 2.1
now I'm trying to quickpwn it.
but when i try to click the blue button to even begin the process, i get this...
seriously need help!
has anyone encountered this?
H
Hayesimus
Guest
it is 2.1. iTunes says so. i've heard i should try to reboot my computer first so i'm gonna try that route real quick.
H
Hayesimus
Guest
D'oh. Well apparently that was it. lol. stupid technology...
H
Hayesimus
Guest
so how do i put icons and such on my phone now? I used ibrickr before. so now what should i use?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I use Diskaid and WinSCP.
I think Diskaid will work for Mac or PC.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
install winterboard via cydia and then find what you like and pick and choose....if you want to "manually" change it yourself, openSSH would be an option....disk aid, too
H
Hayesimus
Guest
ok i've never used any of those before. do they function much in the same way that ibrickr did?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I'm not familiar with iBrickr. With diskaid you plug the phone into your computer via USB and then you can access the file system to add, remove files etc. I don't even think you need OpenSSH to use diskaid.
OJsakila
Jul 15, 2007
3,021
Have you ever used Cydia, Hayes? Why fu*k with ssh and diskaid right now? Are you trying to do something custom? There are thousands of "themes" to choose from on cydia right there on your iPhone....
H
Hayesimus
Guest
you've seen my theme before. its all custom. i made my own icons.
H
Hayesimus
Guest
okay. where do i go to put my own icons in the application file? I can't remember where it goes. :p
