I need to know (please help)
Techno_man
Oct 27, 2007
56
Guys how do u get connected to the internet on your iPhone when u plug it in your pc ? it doesn't seem to work any advices? ideas how to work this ? :(
Note: i don't want to use wifi or edge just my get internet from my pc to my iPhone!
thanks in advance
runcmd
Aug 6, 2007
46
Rabun Gap, GA
thanks in advance
Not sure what you're asking so clarify for me.
Do you want to sit at your PC and use the internet coming through your phones data connection ?
if so - here is a link to a discussion/walk-through on this topic on this site: HERE
There are other discussions here at EI if you want to search more.
or
Do you want to use your iPhone to browse the internet while using your home internet connection instead of the builtin edge ?
[if this is the case, then you are going to have to get/use a wireless router/access point. The only way I know to currently access the internet from the iPhone using your home connection is over wifi.
others here may know more.
