I took my iPhone SIM card out and put it in a BlackJack
SpunkyXL
24
Will I get billed If I use the internet on my Samsung Blackjack since I am using the iPhone plan? I was surprised my Blackjack works with the iPhone Sim. I'm just worried I will get billed If I use the internet. Can anyone Confirm this?
alb0zf1n3st
Jul 2, 2007
624
you probably will even though the iPhone has unlimited data I think the blackjack is almost like blackberry plans and has special ones but thats my take on it.. wait for another person to confirm this I wouldn't use it until you know for sure.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
My guess would be yes as the unlimited pda data plan is more than the iPhone data plan. But like i said just a guess.
ebrunn
Feb 6, 2007
711
Minneapolis
I was under the impression that th data and text messenging would not work if you took the sim card out and replaced it in another phone.
VIPERxGTx2000
Jul 7, 2007
112
No you shouldn't be billed differently, the network isn't going to know if your using data on a blackjack or data on the iPhone, their both treated the same way, along with text messages.
SpunkyXL
24
If I keep my iPhone Simcard on my Blackjack, and RETURN my iPhone, will my Blackjack continue to work? Or once its return, my iPhone Simcard is de-activated?
stiphone
Jul 10, 2007
76
Tucson, Arizona
Nope. I think that you would not be charged. This is because I was using MediaNet with my unlocked Dash before switching over to the iPhone. It requires just a data plan that is the same as the iPhone. Anyway, just for your information, my previous plan was unlimited data at $19.99. Except that it does not include any free sms messages. Hope this helps.
minivini
Jul 6, 2007
418
I was told at the ATT store that only DATA would not work with other devices - all other cell services should work. If you put it in your Blackjack and try to access a website, does it work? Have you tried checking your email?
I'd be curious to know.
Also, I'm now curious about the fact that they ARE using a 3G card. Maybe that's all they issue now?
SpunkyXL
24
yes, txt msging, internet work. I was just on www.cnn.com on my Blackjack....man, 3g, loads so much faster than Edge!
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
You can always access the internet with a cingular/AT&T plan. The question is whether the data will be covered by your iPhone data plan or whether you're being charged $.01/Kb?
jjvaldez
Jul 3, 2007
2,615
35
Salinas, Ca
im sure that you will not get billed for this.. before i got the iPhone i had a treo that i used for 8 months with the medianet lpan [this is the plan for the razor and those such phones] and i was fine... unlimited!
GP78
Jul 2, 2007
23
NJ, USA
I switch between my 8525 and my iPhone almost constantly. No problems, no issues. (I need stuff on my 8525 for work, like push email, and the ability to terminal into my servers.)
Leslienation
Jul 10, 2007
24
that's a good question. I got a BJ too. what to know that answer. Tkx OP
chakraj
Jun 30, 2007
People. AT&T employees are clueless they only repeat the garbage given to them by there bosses. There is no way for them to tell what phone you are using. there is no difference with the data on windows mobile and iPhone. the visual voicemail is the only iPhone specific part of the equasion. now black berry uses a propriotory data transfer but windows mobile and iPhone do not. However the people at AT&T no nothing. they are less informed than all of us
Flyinb
Jul 9, 2007
23
www.400N.com
I have a Blackjack as well, I always swap out the sim from my iPhone into the blackjack so I can use it as a modem for my laptop. ATT will have no clue what phone your sim is in, they read the sim info not phone info.
JeffBobula
Apr 20, 2007
257
34
Madison, Wisconsin
Thats a good trick! How do you pull that off though? Bluetooth or something? (The laptop to blackjack combo)
Flyinb
Jul 9, 2007
23
www.400N.com
OK here it is the best way,
Connect Blackjack via USB cable to PC
Once connected go to My Computer and open your mobile phone.
Click on the windows folder.
Scroll down till you see a file called "Internet Sharing"
Right Click and create shortcut.
leave this folder open.
Go to My Computer and open Mobile Phone again.
Click on windows folder.
click on start menu.
drag the new shortcut you created (its now in the botton of the windows folder called Internet Sharing 2) to the start menu folder.
once this is done close all folders.
now on your Blackjack go to start menu and find new icon for Internet Sharing and click set settings for usb and click connect.
Make sure you turn of wireless on laptop.
Surf away
