I updated something and OOPS.
Aug 16, 2007
24
I updated a couple of apps and my screen is black. The only thing that appears now is the sunburst (which thankfully works) of course I have modded my iPhone. Did this happen to anyone else?
gcvt
Jun 21, 2007
1,029
San Francisco
That happened to me a couple of times. I'm new to modding phones and couldn't find a way out other than a restore. But, since my last 'blackout', I read some tips to try before restoring.
I can't remember the name of the thread though. Maybe try some creative searching while you wait for more knowledgeable people to stop by. Best of luck.
Aug 16, 2007
24
Thanks will do.
garretwp
Sep 3, 2007
125
Does your dock still appear with some icons? If it does, download rsbt from the installer.app and you should be able to arrange what will appear on the home screen. You can choose what to keep hidden and what to display on the home screen. It sounds like most of your apps are hidden.
- Garrett
Aug 16, 2007
24
- Garrett
No. The screen is entirely black. All that is there is the bar at the top that tells the signal and the sunburst in the corner (which works). Also my settings have changed to where if I press the circle button, the phone locks instead of turning back to the main menu.
The Apple
3,105
Indiana
And shutting your phone down and turning it back on did not fix? My phone froze and I had to reset it, but it worked fine afterwards.
Aug 16, 2007
24
Mine isn't frozen. I have tried that though and it stays the same.
garretwp
Sep 3, 2007
125
Can you back track on which apps you updated? Maybe there is something else that is causing an issue and we are not realizing it.
- Garrett
Aug 16, 2007
24
- Garrett
I've updated all the ones I have installed (which is too many to count).
garretwp
Sep 3, 2007
125
Are you able to access the installer? If so, then I would suggest that you delete each app one at a time and see if that corrects your problem. Something it causing your phone to act weird. The only other suggestion I can recommend is to do a restore of your phone.
- Garrett
The Apple
3,105
Indiana
yeah some applications are very unstable. If it says unstable I stay away!
Hamadeh
Sep 3, 2007
im having same problem. has anyone fixed it yet?
Hamadeh
Sep 3, 2007
so weird so i turned off fone and turned it back on it was good except a icon was showing there ipong, and then 10 seconds later went to black arrrrrr
Hamadeh
Sep 3, 2007
oh yeah if you connect it to your computer you can see the battery bar green. just when you click slide to unlock its black.
