i4Siri seems to break my twitter apps
emhcee
Apr 4, 2008
246
Anyone else playing around with the i4Siri app and finding that it seems to disable twitter apps? When I run the installation process any of a couple ways (using the i4Siri installer, or manually using just Spire) I can get it to work pretty easily. But then I find that Twitter, and TweetBot stop working. Once I remove Spire and disable Siri, my twitter apps go back to working fine. I messaged the devs about it, just thought I'd float it out here as well.
emhcee
Apr 4, 2008
246
Just to tie up loose ends... Found that even though my JB was working 100% fine, something about the Spire install to get i4Siri running caused problems with a few of my other apps. Installing and running the Corona patch solved the issues, and now Spire works fine as do the other apps.
As an aside, the i4Siri team is getting way too much hype for the mess they've put out there. There are far more reliable servers available to get Siri running, though there doesn't seem to be much interest in these forums. O_o
