iBooks and iPad after untethered JB
RPMSTL
Jun 22, 2009
251
Anyone get iBooks working on a gen 1 pad?
iBooks fix2 works on my 3GS but no joy on the pad.
I have tried every method on the net including the latest versions of corona and Redsnow.
RPMSTL
Jun 22, 2009
251
I believe I have iBooks working. I redownloaded a book I previously purchased from the iBook store and everything seemed normal.
Restored to iOS 5.01 via iTunes.
JB with Redsnow 9.10b3
Installed SBsettings
Deleted iBooks
Respring
Installed iBooks via App store
Installed iBook Fix2 from Cydia (you need to add a repository - Google it)
Respring
All is good. I tried many different versions of the above instructions but this exact procedure did the trick.
fijiman
Feb 13, 2011
832
64
UK
Here's an Attached .deb file for iBook2...if it helps.... either run it with iFile on your iDevice....or just just SSH into the Cydia "Auto install" folder and reboot.
