iBooks help
Sam91
Sep 10, 2010
Bought and downloaded a new book, but for the past few days iBooks has only been crashing. As soon as I click the book it kicks me off. Why is that? Can i fix it?
5,580
First try rebooting. If that doesn't work, uninstall the app and then reinstall it.
Sam91
Sep 10, 2010
Yeah I did that. A lot. It just won't budge. Keeps quitting and going to home screen after a mere 3 seconds. Really wanna read my book. it's frustrating
5,580
Is your phone jailbroken? If so, which jailbreak tool did you use?
5,580
Moved to iPhone Jailbreak forum.
It sounds like the jailbreak broke iBooks. Some of the early versions of redsn0w for 4.x did this. Running an updated version of redsn0w on top of the old version that you have should fix it. Be sure to uncheck the box to install Cydia since you already have it installed.
Sam91
Sep 10, 2010
That's all it took Europa, thanks! Now I can enjoy my book.
