iBrick question
RHJS
Jun 18, 2007
130
SoCal
Hey I just got iBrickr today and tried adding some ringtones but for some reason its taking really long? Its been at the transcoding step for about 15 minutes already.
Any help? thanks
BoxKrait
May 16, 2007
144
Happened to me once when I tried to take the *.mp4 off the end of the file.
But if I just leave it alone it works fine.
pooh
Sep 3, 2007
20
Baton Rouge, La.
personally i never use it for ringers just apps and stuff, but try iPhoneringtonemaker seriously... i make ring tones in 2 mins the longest part is editing the song and somehow its still fun though:laugh2:...
x999x
Aug 6, 2007
1,656
Transcoding would imply that it's not even gotten to the bit where it actually transfers the sound file to your iPhone yet. iBrickr is still trying to convert your file from one format to another. It sounds like your source file isn't one that FFMPEG likes, even though it should "theoretically" accept every type of format.
If you can, re-encode your original file and then try running it through ibrickr again. Alternately, you can restart your computer to try again, and if that doesn't work, you may want to install some codecs to handle your audio decoding/encoding:
http://sourceforge.net/projects/ffdshow
FFDShow is a very good codec, I've not had any problems with it and it complements AVSynth and VirtualDub very well. The only thing you may want to do is edit it's configuration to not show the tray icon every time its decoding something, it's kind of annoying, heh.
