iBrickr replacement
Nov 6, 2007
Is there an application on pc like ibrickr, for installing applications via usb on the iPhone. I just updated to 1.2.0...so ibrickr doesn't work any longer
15,385
1,089
do you mean 2.0.1? there wasn't ever a 1.2.0 software version...
I'm not sure of another app to add files/apps through USB, but most people just use an SSH app like WinSCP to wirelessly add/change files on jailbroken iPhones. you will also need openSSH and BSD subsystem installed on your iPhone for it to work.
Nov 6, 2007
I meant iPhone firmware version 1.2.0. I am having problems with my cydia and thus cant install openSSH on the iPhone. So i have to manually transfer the files
15,385
1,089
If you have cydia, then your iPhone firmware is either 2.0.0 or 2.0.1. Just a technicality, i guess.
Anyway, i'm not sure of an ibrickr equivalent for windows off-hand. What are the problems with cydia you're having?
Nov 6, 2007
cydia always reports an unknown error at startup. I cant seem to download anything off it, neither does it refresh. From other sites, i hear it has to do with a wifi issue cydia has.
Any experiences?
zenon
Oct 28, 2007
Iran-Tehran
iPhoneBrowser v1.5.2.0 can connect to iPhone 2.0.1 with USB(for Windows),I try it!
