iBrickr won't connect to iPhone
Aug 25, 2007
I have installed iBrickr, installed multiple apps and now want to install ringtones. It will not connect to my iPhone.
I have rebooted the computer and the iPhone.
Im on Vista and the iPhone is on 1.02.
Any thoughts?
Ken Iovino
Aug 28, 2007
I was having the same problem and here is what I had to do to fix it.
Click Start & Run then type:
C:\Program Files\Common Files\Apple\Mobile Device Support\bin
locate the file titled "iTunesMobileDevice.dll" and copy it into the iBrickr folder. Once you do that try running ibrickr.exe again.
Hope this helps :)
justahsquirrel
Jun 7, 2007
545
Queens, NY
Hope this helps :)
where did u get his information from?
