iCafe app problem...
FuelieNova
Aug 3, 2008
636
33
I am not able to post anything from my iCafe app. To the best of my knowledge I am logged in.
Any help?
Tom
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
Tom-
Are you seeing the 'Dashboard'? That's the easiest way to confirm that you are logged into the site via the app.
Within a category, select the arrow at the top right and select 'New Topic'. Within a thread, you can select this arrow and then reply.
FuelieNova
Aug 3, 2008
636
33
Chris
Thanks for the help. I am not seeing the dashboard... I still haven't figured out where to login at :)
Remember... not all people on this forum are young :)
Tom
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
Chris
Tom
Try this:
  • Exit the app
  • Double-click the home button
  • Press and hold on the everythingiCafe app until you see a '-' sign
  • Press the red minus sign
  • Open the app from your home screen
  • At the bottom left you should see a button that says 'Login'
Let me know how you make out.
Please note that version 1.8 has an issue that causes users to be logged out when leaving the app. This will be resolved in version 1.8.1.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Maybe this will help.
When u click on the app you should see this screen
Click in login on bottom left. The. You will see this.
Enter appropriate info. Then you should get this screen.
If this doesn't work. Close the app out (task manager) then try again.
  • Like
Reactions: chris
FuelieNova
Aug 3, 2008
636
33
OK
When I first boot up the app it goes to the dashboard and says I must be logged in to do this :)
If I switch to latest, I get the above screen but no login button at the bottom.
I did make sure I closed the app before rebooting.
I am running iOS5 GM... could this be a problem?
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
OK
Have u tried deleting the app completely and reinstalling it?
Hillbilly
Feb 9, 2011
160
14
FYI: I get randomly logged out. I have iPhone 4 VZW (not jail broken).
Not that big of a deal as I just log back on but letting you know.
iPutz
Nov 20, 2012
964
183
43
73
US Midwest
I got the same messages about 30 minutes ago via the mobile app then they stopped about as suddenly as they started. No clue what happened or what cured it.
iPutz
Nov 20, 2012
964
183
43
73
US Midwest
The problem only appeared to be happening for 30 minutes. I had checked the app a few minutes earlier without issue then received an alert within 10 minutes and discovered the problem. Tried a hard reset first then re-installed the app and it still was having the same issue. I switched from Wi-Fi to the cellular data network and still had the issue. Next I went to the online page and got in no problem. I then switched back to the mobile app and all was working again on both cellular data network and on Wi-Fi. The two messages shown above by Ledsteplin are identical to the ones I got on my iPhone 5 on AT&T using the latest version of iOS. Time to scratch our heads I guess.
