iCal sync problem
Variant
Aug 10, 2007
Well, I think I found a new bug. When I try to sync my iPhone with iCal I get this message:
"iTunes could not sync calendars to the iPhone "Lisa's iPhone" because an error occurred while mingling data."
I have deleted the calendars from iCal, trashed the plist file, tried everything I can think of. Any help is GREATLY appreciated.
realnyc
ICal Sync Problem too !
I have the same problem and tried everything ! Frustrating ! I read somewhere that if you have multiple calendars, then switch the automatically sync calendars OFF and Manually sync ON, then drag your calendar [ie:home] to the top of the list. That didn't work for me either.
I also get the message...."" iTunes could not sync calendars to the iPhone, because an error occurred while mingling data." but I get an added..."an error occurred because iPhone disconnected", but it didn't disconnect...
One time I did get thee messages, and it did sync, but it put 3 duplicates of each calendar item in my calendar on my phone, so I had to wipe everything and start over...
Hope any of this helps...
HEY APPLE ! WHEN IS COPY/PASTE GOING TO BE IMPLEMENTED ?!
Variant
Aug 10, 2007
New hardware? Could that be the culprit?
Question for realnyc: Are you attempting to sync on new hardware? I realized that this is the first time I have tried to sync the iPhone after tranferrring all user data from an old computer.
Variant
Aug 10, 2007
Problem solved!
I managed to successfuly sync last night, without the "mingling data" alert.
I simply entered all of my events into iCal and then replaced all calendar data on the iPhone with data from iCal. It worked.
hpaynter@mac.com
Feb 8, 2009
I don't seem to be able to sync my MacBook Pro iCal to my iPhone. All other apps (mail, contacts, etc) sync just fine. What gives?
llrickman
Jan 12, 2008
787
26
Albuquerque , NM
Do you have the box checked "Sync Calenders" (under info tab ) when u attach your iPhone? I think that's what it is . I don't see that one anymore since i sync calendars with mobile me over the air
I just notice u have a .Mac address are you syncing over the air ?
.Mac is the same thing as Mobile Me now isn't it?
now im confused im not sure what the problem is lol
