iClarified - How to Jailbreak and Update to 1.1.3 iPhone Firmware Using Windows
Goodlife08
Jan 23, 2008
53
does this update remove the installer apps pre installed from 1.1.2
also i've been wondering do you have to pay for each app cause i don't want to have a 200$ for all these apps im installing!
KTORRES1120
Dec 28, 2007
53
Yeah, I'm wondering too if all your apps will be there when this is all done or if you have to install everything all over again? When doing this, does iTunes backup your contacts, sms messages, emails, etc? I don't wanna lose everything!
jacker28
Jan 16, 2008
11
question
Do you have to have an activated 1.1.1 or 1.1.2 jailbroken iPhone? I updated to 1.1.3 so if I go down to 1.1.1 with the installer app installed, I can do the jailbreak to get back to a jailbroken 1.1.3 iPhone that is activated?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
uninstall summerboard and a couple of other things, but I know when I'm going to upgrade, I'm going to write down what I had then uninstall it.
Possible timesaver, depending on how many apps you have installed - I took a few quick screencaps of my apps screens, mailed them to myself, and then used those for ref when re-installing stuff under 1.1.3 ...
