iCleaner Pro [App]
iphonewarrior
13,847
701
iCleaner Pro has just been released for iOS 7.
You can download it by adding this repo:
Code:
http://exile90software.com/cydia
iphonewarrior
13,847
701
@MoneyMaker79 This app can be used to remove unused dependencies, instead of using Mobile Terminal (although the app effectively runs an apt-get autoremove command; this command is one of many you could run in MT).
Dec 15, 2008
5,386
340
27
Pensacola, FL
Thanks for this. I had iCleaner but of course I was waiting for it to be updated. Can you explain to me cleaning Cydia sources?
iphonewarrior
13,847
701
I see. Thank you. I should learn to read this file and others / directions, but I'm like my dad. I don't read directions or ask anybody for directions when driving. Hehe.
We're men. It's not in our genetic code. I forgive you! :p
Dec 15, 2008
5,386
340
27
Pensacola, FL
Well thank you for forgiving me. And you are right I'm sure. A lot of men just don't like to ask or find directions.
Aside from this and way off topic, but I wish I could post smileys using the app.
iphonewarrior
13,847
701
Use Safari/Chrome :p
28,365
5,506
True haha. I can comment using the app then quickly go login on safari. It's just inconvenient. Maybe smilies will come in time. That'll be cool.
You could just use mobile Safari as a primary way of accessing the site.
Kadelic
Jan 4, 2010
4,940
1,646
Dallas, TX
...I wish I could post smileys using the app.
I use emoticons all the time with the app. You just "spell" them and they forum software turns them into the appropriate emoticon or smiley.
I'm adding spaces to demonstrate.
: D = :D
Etc. ;)
Dec 15, 2008
5,386
340
27
Pensacola, FL
: D = :D
Etc. ;)
Thanks. I never thought of that. : )
Ok I knew you could do this, but it doesn't show the actual smiley on the app. That's what I meant.
Dec 15, 2008
5,386
340
27
Pensacola, FL
After you post the reply it shows in the app, or it does for me.
Interesting. I don't see the actual smiley. Just the spaced one.
Yay now I figured it out. I have to do the non spaced and then cancel the auto and I see it.
