iCloud = Gmail?
SweepeR
Oct 1, 2007
367
I don't get this iCloud businesss. It says I have already used 4.5 GIGS from my 5gigs and i have yet to upload pictures or e-mails as I put my gmail account in it and it doesn't sync my gmail i guess.
says most of the gigs is for iPhone back up...meaning contacts i assume?
says in order to do e-mails you need to make the @me.com e-mail.
So I can't sync gmail to my outlook from my phone with calendar? I put something in the iPhone calendar and didn't sync to outlook or iCal. Is it b/c it is my gmail and not the @me.com email?
if so, can i forward everything form my gmail to a @me.com email i make? so I don't start all over.
SweepeR
Oct 1, 2007
367
do you do that from your gmail settings?
dude, where do I check my iMessages to chat from my macbook?
I thought ic an talk with people on iMessage from the mac?
gotta be honest, this is a very shitty method of getting people instructions by Apple.
15,385
1,023
yeah, forwarding is in gmail settings.
you cannot check/send imessages through a computer as far as i know. Maybe you're thinking of facetime... you can facetime people on a mac.
theorioles33
Jul 21, 2007
925
135
USA
Check your settings under iCloud. It shows the apps and how much space they are using in the cloud. I found that my GPS app and my Zinio app was backing up to the cloud taking up a couple gig. I turned them off so they don't backup.
SweepeR
Oct 1, 2007
367
so why does it say you can talk to ppl on iMessage via macbook, iPod, iPad, iPhone?
SweepeR
Oct 1, 2007
367
and whats the point of iCloud? I thought if I upload it from my iPhone to my mac i can go into the iCloud app on the macbook and access the files there?
15,385
1,023
which files? Photos go to iPhoto through the photostream. Documents go to Pages, Excel, Keynote, email goes to mail...
SweepeR
Oct 1, 2007
367
so i have to use the Mac e-mail i can't with outlook? now here is my question i guess, if all it does is still sync everything to its original destination such as mail, iPhoto etc. whats the point of it? doesn't gmail ALREADy store its mail in its own server? all this is is basically saving stuff onto Apples server to send over to gmail or instance.
for example, i add something in all my calendars, outlook to ical and even my iPhone and they NEVER sync to the other device on its own. i am still adding them 1 by 1 per device.
15,385
1,023
you can. I was just speaking from a Mac perspective.
it syncs everything to all of your devices. not just the original location.
doesn't really have anything to do with Gmail. with iCloud you get a separate email account. I forward from Gmail because I didn't feel like updating my contact info everywhere.
Not sure about that. iCloud should take care of it for you.
ctmed5408
Jun 24, 2010
20
Been using Google calendar for about a month. It syncs with my iPhone just fine and has worked great for me. Now that I upgraded to iOS5, my small feeble mind isn't understanding how to use the cloud instead to do the same thing. All I want to ultimately do is be able to sync the same calendar between my iPhone, ipad and desktop(windows) PC. How can I do this using the cloud or can I?
15,385
1,023
You can. You just need outlook 2007 or later on your PC and to install the windows iCloud software.
SweepeR
Oct 1, 2007
367
my outlook that is using a gmail account on my macbook isn't syncing to my iPhones calendar but i did get it to sync to my iCal.
what settings should it be in on my iPhone so it connects to my gmail calendar in outlook.
swampduck
Oct 19, 2007
164
If you are using gmail, you already have the ability to sync your email, documents, calendars between all devices that you use google on. The iCloud is just a different way to do it, there is some other new things built into it, but it is essentially the same principal
We Beat U
Mar 1, 2008
107
My question is, if apps aren't charged against your 5gig quota, why does it show me as already using .5 of a gig for storage? Almost all of that are apps. Shouldn't it just show you how much your are actually using?
