iCloud keychain passwords not available on iPhone
jareknyc
Aug 27, 2007
714
NYC
My iCloud password are not loading on my iPhone, they do exist on iPad and iMac but not my iPhone...I did completely remove iCloud account also turn on and and off keychain with no luck...still no passwords or credit cards
Ledsteplin
Oct 29, 2013
4,817
985
65
Florence, AL
Did you log back in to iCloud? Is it the Keychain passcode you need? It's likely different from your iCloud password. I use a 4 digit passcode. If your iCloud password works, here's how to change the Keychain passcode.
1. Launch the Settings app on your iPhone or iPad running iOS 8 or higher.
2. Tap on iCloud.
3. Tap on Keychain.
4. Enter your iCloud password if prompted.
5. Tap on Advanced.
6. Tap on Change Security Code.
7. Type in a new code.
8. You can also tap on Advanced Options in order to choose a more complex code or have one generated for you if you choose.
