iCloud messed up my contacts
westgebo
Jan 27, 2012
My contacts got completely messed up on iCloud.
I deleted the Backup Assistant app from my phone but would like to get it back on there. How do I do that?
btw, my contacts are safe and sound on my phone. I just don't want to sync or back them up to what is presently "up" there because it will just send me back the mess again.
Thank you very much for any advice!
jmp316
Jul 10, 2008
1,048
141
My best advice is to edit, add, or delete contacts in the Contacts app on your computer. Or iCloud.com. I've found less errors this way...
Ozzie5374
Nov 7, 2010
422
43
Country South Australia
Hey, same thing happened when I tried "iCloud". Been using google for contacts, mail & calendar for ages and thought I should now use iCloud - being Apple.
Don't bother. Turn off all iCloud and sync to google. Never had a problem with it including new phones/new computers.
jmp316
Jul 10, 2008
1,048
141
I'm the opposite. Had Google contacts for years, just switched to iCloud due to enhanced Siri functions...
Mathew Connelly
Jul 13, 2011
116
I have my most complete contact list in my Gmail. I just made sure to bring it to my iPhone and then sync to the iCloud - you can say that in a way I have also migrated to the iCloud, although I keep my Gmail contact list actively up-to-date.
I think what you are referring to is Copytrans Contacts. I have tried it too but you should choose one method of contact sync only as iCloud will not allow you to sync your contacts elsewhere - for instance with Gmail (via Excahnge) or via third-party apps.
  • Like
Reactions: Patricia04
