iCloud phone group
budala15
Nov 17, 2013
150
When I click on my phone icon and go to Groups I found something under iCloud that I don't recognize. It says all iCloud and then underneath that it has another group labeled as Hoover's. Now I'm freaked out that my phone might have gotten hacked?
Sent from my iPhone 5S using
28,429
5,552
You don't recognize the name Hoover? Do any of your email accounts have that name tied to them?
budala15
Nov 17, 2013
150
Never heard of it. Need to know how to remove it too.
28,429
5,552
Go to Settings > Mail, Contacts, Calendars and select each account one at time. First toggle off the calendar check to see if it disappears in the calendar app. If that doesn't work, delete the account.
budala15
Nov 17, 2013
150
Unfortunately that didn't work.
28,429
5,552
Delete all of your email accounts from the phone and reboot. Check the Calendar app after that and add the accounts back in.
budala15
Nov 17, 2013
150
Still no luck.
budala15
Nov 17, 2013
150
The name still shows up.
28,429
5,552
Okay, I'd reset all settings in the Settings app. Be sure to check the calendar app afterwards. It will take less than ten minutes to set your phone back up (set wallpaper, ringtones, WiFi passwords, etc.), and you want to make sure it's gone before inputting all of this stuff.
budala15
Nov 17, 2013
150
Do you know how a name gets in this specific group?
28,429
5,552
I'm not sure how it got there, but it sounds like the name of an email account. Mine showed my Gmail account under "other" before I disabled it in settings.
budala15
Nov 17, 2013
150
How did u disable it?
budala15
Nov 17, 2013
150
It was a long time ago, but I think I just toggled it off like I showed in my second post in this thread.
Appreciate your help!
