Icon Camera iPhone 4 disappeared
verwon
Jul 29, 2011
1,015
121
Seattle
Exactly what do you mean lost? It's a stock app, so it can't be deleted.
Did you perhaps just put it in a folder?
Sent from my iOS ecosystem!
alone979503
Oct 25, 2011
Hi
I checked in all folders it's not available but when I check from search iPhone page and write Camera system will show me the icon
Lon
Jun 5, 2010
2,946
132
Alaska
Hi
I would do a reboot and hard reboot before doing anything else more drastic.
Also, check in Settings>Restrictions and make sure it isn't turned off.
alone979503
Oct 25, 2011
Settings > General > Reset > Reset Home Screen Layout
In order to do above entry, my phone is jailbreak is IR ok to do use above way to reset and may I know if not effect any applications which I downloaded
FitPro
Nov 16, 2011
I lost my icon camera, how I can reinstated back
Thank you
Hi I just had this problem and found that I accidentally restricted the use of the camera which made the icon disappear. Go to Settings; General; Restrictions; and make sure the Camera is in the ON position.
