if i get a new phone will i be able to restore from previous device?
Ezekiel2517
Sep 20, 2007
693
i recently lost my iPhone 3g and i am wondering if i get a new replacement one, if i would be able to restore the data from the one i had. i am thinking that the last backup was made right before i upgraded from 2.2 to 3.0. if all else fails, i should be able to restore to 2.2 to use that save, right? but i am also wondering if i get the 3gs, if it would let me restore to 2.2, even though i doubt it would. i am thinking about just getting a regular 3g, but if i have enough, and the restore works, ill think about getting the 3gs.
any answers?
iphun
Mar 16, 2009
1,967
PA
When you get the new phone it won't be on anything less than 2.2 unless it is a 3GS which will be on 3.0/3.0.1. A 2.2 backup will work on 3.0, but a 3.0 backup is not compatible with anything less than 3.0. If you get a replacement you should be fine.
