if i want to update?
thepunisher1991
Jul 30, 2007
72
should i just restore and update even though i have 3rd party application? can anyone help me idk if i should update it because i have3rd party applications
jjvaldez
Jul 3, 2007
2,615
34
Salinas, Ca
sync, then restore then update.. you will lose all 3rd party apps...
bfakhroo
Oct 2, 2007
132
you don't have to restore you can directly update
No restore required, the updating process includes a restore.
Note that if you are running firmware 1.0.2, and are upgrading to firmware 1.1.1, you will still be able to use third-party apps.
But if you are using firmware 1.1.1, and upgrading to 1.1.2, first install Okto Prep from Installer, then update, and then you will be able to jailbreak again. If you do not install Okto Prep, you will not be able to jailbreak your phone.
-John
thepunisher1991
Jul 30, 2007
72
The if I already did what do I have to do
-John
colombianito
Sep 12, 2007
166
I have 1.0.2 so how do I make sure I update to 1.1.1 and not to 1.1.2 when i select "update" on iTunes ?
thepunisher1991
Jul 30, 2007
72
Ok so go to modmyiPhone.com the go to dowload and the go to firmeware the download 1.1.1. On iTunes your gonna press and hold shift and click restore then look for the firmware were e we you saved it at and that should work
