if im an AT&T Existing customer..how much is 3G for me?
xomwah
Apr 28, 2008
34
if im an AT&T Existing customer who has never owned the first iPhone how much will 3g cost me?
is it $199/299 or $399/499?
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
If you are eligible for an upgrade then you will get the subsidized price of $199/$299. If you are not eligible for an upgrade and have not owned an iPhone before then the price is going to be higher.
jarofclay73
Jun 23, 2008
2,387
Honolulu, Hawaii
If you are still in your 2-year contract, it'll be the higher price for you. If your 2 years are up and you're eligible for an upgrade, it's the cheaper set. And if you're a current iPhone user, it's also the cheaper set.
kevlar08
Jul 3, 2008
1,140
Colorado
how long have you had your plan?
most likely the phone will be the 399/499 price for you, if you can upgrade you'll get the 199/299 price
