If it were unlocked...
srose
Jun 10, 2008
57
Hi
I am thinking if buying an iPhone 3G when they are unlocked so that I can run my Vodafone Pay as You Go SIM on it.
If I were in a 3G area and checked my mail or used the GPS (which uses 3G?) would this charge me money every minute?
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
If you try using 3G and aren't subscribed to a 3G data plan then (if it allows you to connect) you will be charged. On AT&T at least, a few years back, if you accidentally hit the internet button and loaded something then you would be charged so I assumed that would be the case with Vodafone.
srose
Jun 10, 2008
57
As long as the provider (Vodafone) has 3G will it connect on pay as you go? For push e-mail would that mean I would be constantly charged as long as the 3G setting is turned on?
