Ignore Calls?
bkushner
Jan 22, 2008
70
Is there a way to IGNORE or send a call to voice mail when the phone rings and you get the main screen with the SLIDE TO ANSWER message? I know you can ignore if the phone is in use but haven't found a way to ignore a call on a sleeping phone.
Brian
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
hit the top button twice
Once turns the ringer off but it still rings for the caller
Twice sends the call straight to voicemail
bkushner
Jan 22, 2008
70
Okay got it thanks..
Brian
Mar 1, 2008
if you hit decline it will do the same thing as hitting the top button twice, correct?
