iHome dock
elmosettle
Oct 23, 2009
23
As many of you know.... If you own an ihome dock that played all previous idevices it no longer works with an iPhone 5. Into even with the lighting converter. Does anyone know if there is an app in cydia that will bypass this? I would like to continue to listen to my music. Thx
Sent using iCafe app
iPutz
Nov 20, 2012
964
183
43
73
US Midwest
Did you buy the adapter from Apple or through your carrier or is it a 3rd party adapter. According to Apple their lightning to 30 pin adapter should pass iPhone 5 audio through to older audio accessories that used the 30 pin connector. 3rd party lightning accessories are a hit and miss proposition so far.
Sent using my iPhone 5
iPutz
Nov 20, 2012
964
183
43
73
US Midwest
Probably do need the one from Apple, I would confirm with them before you buy it that it will do what you are expecting it to. Good luck.
elmosettle
Oct 23, 2009
23
So the box connects to the ihome and iPhone connects to the receiver via Bluetooth?
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
The adapter connects to the 30-pin and sends music to the iPhone via Bluetooth. If you want an alarm to work, which is what I wanted, you need to DL an app for that. It won't work with the stock Apple clock app.
iPutz
Nov 20, 2012
964
183
43
73
US Midwest
Yes, that will send music to the dock from the iPhone via Bluetooth. I use a similar item that plugs into a 110 volt outlet and connects to an input on my surround sound system to send music from my iPhone to the system. Any system sound (phone ringing, e-mail notification etc) mutes and pauses the music and plays the alert sound via the iPhones speaker.
