iLyrics now available for iPhone
Sep 29, 2007
348
iLyrics is now available for the Apple iPhone. It is able to find and save the lyrics of songs on your iPod. It was originally written in Japanese but is now available in English.
It is not available on installer.app as of yet so you will have to use other clients such as Fugu to add the application on to it. Edit: You can get it via installer.app but it comes in Japanese and you have to use iBricker to fix it else wise.
What I did:
-Download this http://lyrics-app.googlecode.com/files/Lyrics.app-touch-v0.021.zip
-Draged and Dropped the Lyrics.app into the /Application folder of the iPhone using Fugu. (If needed I will post how to work Fugu)
-Restarted iPhone.
-Clicked on the Lyrics Application.
-Went to "Lyrics"
-Double click homebutton to go to iPod
-Find a song and play it
-Click home button and go back to Lyrics app
Alternate Way thanks to colombianito
colombianito said:
ok...got it to work !
first off... thanks to zabumafu for bringing it to us...
now...go to installer, add a source and add this source: http://hpcgi3.nifty.com/moyashi/ipodtouch/repository.cgi
then refresh and go to the multimedia section on the install part on installer... you should see the ilyric app, install it... atthispoint you have the app in japanese... now... if you want it in english:
download this and using ibrickr or whatever program u use to acces the files on your phone, go to applications/lyrics.app/ make a new forlder named: English.lproj, go to the folder you downloaded above and put the file that is in the folder English.lproj to the folder you've just made on your phone...
restart your phone...
start the ipod, go "home" select lyrics.app, go to lyrics and it should start looking for lyrics... mine didn't find any, but i think now that is just matter of selecting/changing the source where it is looking for the lyrics...
thanks again to the OP and i hope this helped...
It will begin searching and is usually quite fast. It needs Edge/Wifi connection so if no results are found that may be why.
When it finds the lyrics it will save it in your library.
It is a great application and you can find it here.
http://code.google.com/p/lyrics-app/
Instructions:
http://lyrics-app.googlecode.com/files/Lyrics-app-ReadMe_en.txt
colombianito
Sep 12, 2007
166
wanst able to make it work...
i would love to hear form someone else who got it to work and maybe see some screenshots with the english version...
i see the icon and all but when i tap on it, nothing happens...
Alexander
Jun 28, 2007
1,724
Atlanta
Same. Click icon, lined screen comes up - and that's it.
colombianito
Sep 12, 2007
166
mine stays on the lined screen for a little and then just closes by itself... :( bummer...
Sep 29, 2007
348
Ill get some screen shots one sec.
Edit: Uploaded some screenshots
colombianito
Sep 12, 2007
166
and some more detailed step by step if possible....
thanks...
Sep 29, 2007
348
Maybe try downloaded the older version. That is the one I have and it works fine. I couldn't get the older version to work. Make sure you drag the application that says .app into it.
Sep 29, 2007
348
thanks...
I gave a readme file along with it. I updated the steps and gave the link to the file. I will edit right now and add some more detail.
colombianito
Sep 12, 2007
166
Sep 29, 2007
348
Good job. I added it to my original post if you don't mind.
colombianito
Sep 12, 2007
166
i cant figure how to change the sources where it is looking for lyrics... ill keep looking but if anyone finds out please post it...so far the app has found some of the michael jackson, limp biskit?, guns n roses and few more...
amazing app !
props to the creator.. ! love it !
smokepsp32
Dec 2, 2007
45
great...
will try this one...
colombianito
Sep 12, 2007
166
has anyone found out how to change the source of the lyrics?
Jul 7, 2008
the link doesn't work.
i cant download the .zip file from google.
any other links like megaupload or rapidshare?
