iMessage problem
Sharunda
Jun 16, 2008
4,992
1,100
One Horse Town, New Jersey
#21
Well she says she is on interne but not sure if wifi... But ye ill tell her to take off imessages and then put it back on
Sent from my iPhone 4s using iCafe app
You definitely need a WiFi signal for FaceTime. She can tell if she's on WiFi by the symbol on the left hand side top of the screen. The symbol has three little curves at the top instead of it saying 3G the symbol is in its place. This is located next to the carrier name.
Turning the iMessage off and then back on should fix her problem.
Let us know how it turns out.
Buc0727
Mar 13, 2012
32
30
Texas
#22
Please help iMessage is not working on any of my devices how do I reset or fix it help
Indy
Jul 29, 2007
2,921
40
#23
Just found this on the Apple support forums...may help you out. Of course I don't have a "Mac", so I don't understand 'tick' and 'unticking'
"If you still have problem with Imessages on your Mac.... i have just tried this go to Messages and then click on account... then untick your Imessages..... After that go back to Messages and account and tick your Imessages account it will ask you for your password (type your password) and that should wok.."
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
#24
"Tick" is just another way to say "Check" or "Select". Ticking something just means to click on its checkbox to make the checkmark appear. Unticking is the opposite.
Sent from my alphanumeric pager.
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
#25
Just a reminder, you should make sure iMessage is enabled on your devices. Go to Settings > Messages and make sure it's on.
Also, make sure the person you're trying to send an iMessage to has a device that supports iMessages ;)
Girdler
Aug 1, 2012
283
44
29
#26
It appears that iMessage(and iCloud) were experiencing issues yesterday. All issues have seem to be fixed.
Girdler
Aug 1, 2012
283
44
29
#27
Kobel1up
Mar 14, 2012
160
Eastern Ohio
#28
I learned yesterday that I wasn't receiving text messages, more specifically iMessage. Lots of texts sent from my phone to my wife's that were not received and vice versa. I sent iMessage to others that I could see on my ipad and MBP but not on my phone.
1 I did a hard reset on both iPhones
Didn't work.
2 I did a reset of network on both phones
Didn't work
3 complete phone reset and restore
Didn't work
I'm at a loss at this point.
I really don't want to upgrade to the 5 when I could get the 5s this fall. I have insurance so I could get a replacement 4, but I like my phone.
I could jail break and maybe that would fix it.
Any help would be appreciated.
Sent using iCafe app
jmp316
Jul 10, 2008
1,048
141
#29
Make sure iMessage is turned on? Settings > Messages > iMessage > On
jmp316
Jul 10, 2008
1,048
141
#31
I checked that yesterday just forgot to put that in my list.
Gotcha. I have no other tips beyond what you've tried. Good luck getting it working again!
Kobel1up
Mar 14, 2012
160
Eastern Ohio
#33
Just a follow up. I took my phone to Verizon and they did a network update and that fixed my issue.
5,580
#35
Never mind problem is back.
Try toggling iMessages off, resetting your network settings and then toggling iMessages back on. It can take an hour or so to start working again after toggling it off/on.
5,580
#37
Weird. It doesn't make sense that this would be hardware. A restore to factory settings should fix it. Have you tried that?
Kobel1up
Mar 14, 2012
160
Eastern Ohio
#38
I did. If I use my email with iMessage it works. Problem is not everyone I communicate with has iPhone or a smart phone. Since my wife isn't having the same problem then it can't be the service.
5,580
#39
Wait. Are you asking why messages sent from non-Apple devices don't come through as iMessages? iMessages is an Apple service. The messages have to come from an Apple device. Otherwise, they come through as texts.
Kobel1up
Mar 14, 2012
160
Eastern Ohio
#40
I should have clarified this better. I can't receive iMessages from any iPhone. I can get some texts from non iPhones, but I really don't have a reliable person to do tests with. One thing I am positive is I can't get a text from an iPhone at all.
