Importing contacts to Yahoo account
Veevee
Apr 22, 2013
20
Hey can someone help me I'm trying to add all my phone contacts to my yahoo account so Incan always sync them to any phone ?
Sent using iCafe app
28,429
5,552
Have you considered using iCloud to sync them? It syncs and pushes contacts over the air.
Veevee
Apr 22, 2013
20
I just want to back them up to my yahoo account would u know how
28,429
5,552
Yeah, unlike iCloud, you'll have to use iTunes on a computer to set it up and you'll have to to sync with iTunes to update to saved contacts. There is a Sync Contacts box under the Info tab in iTunes. It's a subpar method when compared to iCloud. If you add a contact with iCloud enabled, it will immediately push new/updated contacts to your other devices and save them in the cloud. If you do it with Yahoo, it only updates it as often as you connect to iTunes and sync. If you're sticking with iOS I highly recommend iCloud. If you're switching to Android, I recommend syncing them with Google instead of Yahoo.
Veevee
Apr 22, 2013
20
Thank you !
