In store Phone exchange!
301finest
Jun 27, 2007
19
Imma take my phone to get it swap out because of problem but how do they go about puttin all of your contacts back on the new device?
TrippalHealicks
Mar 2, 2007
1,341
You can do it yourself, very easily. Just sync it with iTunes, make sure you have the Windows Address Book checked to sync, and sync it. VOILA!
If you have the same contacts on your PC already, they will be OVERWRITTEN AND / OR COMBINED with the ones from the phone.
minivini
Jul 6, 2007
418
betta make sure they gotta iPhone in stock or you'll be a waitin' on the mail.
301finest
Jun 27, 2007
19
What if i don't have outlook because i manually put my contacts in my phone so how or wat program could i use to put sync my CONTACTS TO?
ben1380
40
Then sync your contacts to your online Yahoo account. If you don't have a Yahoo account then create one.
Standog
Jun 26, 2007
97
Then before you return it, sync your phone with either Outlook if you are on a PC or Address if you're on a Macintosh. This is part of the sync process when you sync your phone, add music, etc. Check for an address app on your computer, it should have all of the contacts that you entered.
As a previous user mentioned, when you get the new phone, resync it and it will simply add everything that you had before. With the exception of notes I believe.
TrippalHealicks
Mar 2, 2007
1,341
Mine actually contained my notes, as well, when I changed over to my temp phone. Somehow, it was synced, as well. ;)
301finest
Jun 27, 2007
19
Im stuck. May someone give me step by steps on importing to yahoo
ben1380
40
Come on...
Make sure you have a yahoo email account.
Open iTunes using your mouse or keyboard for navigation
Connect iPhone to Computer using your hands
Go to the iPhone in iTunes using your mouse or keyboard for navigation
Click the "Information" (I think that's it) tab with your mouse
Under contacts, enable it and pick Yahoo address book or whatever it says and enter your yahoo account information
ATT*Mark
Jul 7, 2007
273
guys....iTunes saves your contact lists for restore. so plug your new iPhone in , click restore and it sends your contacts right to your phone , even saves caller id pics . its like you never changed phones . as long as you plug your iPhone in every day it will be updated.
mjeagent
Jun 28, 2007
418
Northern Virginia
Come on...
Hold on, are you trying to tell me that the mouse and/or keyboard are used for navigation...i call BS.
ATT*Mark
Jul 7, 2007
273
mine says uPhone am i doing something wrong?
ben1380
40
Lol...yes...sometimes I use those archaic devices to select programs.....when Im not on the iPhone that is :)
