incase slider broke :-(
PDACPA
Jan 16, 2008
542
My incase slider broke last night. Not sure how. Picked it up and felt the bottom was loose.
Does anyone know if there is a warranty on them? I might have the case.
Break is clean so I can superglue if no warranty, but would rather get another.
See the picture.
iphonewarrior
13,847
702
wow.
How did it fall? Out of a 4th floor window, then driven over by a 12ton truck!
I suppose you could contact incase and see what there warranty's cover. If you bought it straight from an Apple shop then i'd head back there and try and get a replacement.
Sharunda
Jun 16, 2008
4,992
1,100
One Horse Town, New Jersey
See the picture.
That is a snarky break! Man I hate to see it. Call Incase up. I do all the time. They always say if you have a problem let them know before you do anything.
Here is their number 1888 283 8288 direct 626 338 6400.
They are helpful and should help you out. Send them that picture, they might just replace it totally.
Good Luck!
