Incoming Text Messages
Ayamgah
Dec 30, 2012
Ghana, West Africa
I live in Ghana and use an iPhone 4S with the local Vodafone network. My problem is when I receive a text message it does not come in the name of the contact in the phone but rather with the telephone number with the country code. I am thereforee unable to figure out the name of the sender. In other words, the phone keeps the outgoing text messages in the name of the contact and incoming messages the number. How do I solve the problem?
ivantwilliams
Jul 14, 2009
1,546
218
Do you have the format of the phone numbers correct for the contacts? Look at how the numbers show in the text message and then match it for ONE contact
See if the text window updates to show the same name.
Sent using iCafe app
ivantwilliams
Jul 14, 2009
1,546
218
Ayamgah
Dec 30, 2012
Ghana, West Africa
The problem is that incoming country call numbers are without the country code but incoming texts are with the code. So even if the local contacts are stored with the code it means incoming calls will not also be recognized.
Docd
Oct 16, 2011
651
62
Have you tried turning on dial assist. Don't know if it will help with the issue but it is worth a try.
Docd
Oct 16, 2011
651
62
I never used it but it suppose to add your prefixes automatically. To use system/phone/dial assist.
Ayamgah
Dec 30, 2012
Ghana, West Africa
I think dial assist may be bail able depending on the network operator, especially US based networks. My phone is a factory-unlocked phone used in Ghana. I've not located dial assist in the phone strings after conning it. I used a 3G iPhone before using 4 and now 4S. It is only the 4 & 4S that are giving this particular problem.
CanadianNemo
Aug 31, 2010
1,295
267
Could you have 2 numbers saved for every contact, one with the country code and one without? It would be a pain to set it up, but unless I'm misunderstanding you, it would solve your issue...
Ayamgah
Dec 30, 2012
Ghana, West Africa
Yes. You have understood me perfectly. That is a great idea. May have to do that for over 2,000 contacts! Lol. But then text conversations for incoming and outgoing text messages will be stored separately, and may not make meaning at times until you refer to the other. Hope u get the picture. Thanks.
