Incorrect weather location
Smarty2600
Apr 23, 2011
344
11
The weather app has the wrong location for the current city. So when I pull down the notification center the weather information is wrong. Does anyone know how to fix it? I tried rebooting but it did not work. Also I'm rocking an iPod touch 5th gen.
Also I have tried turning off location services for the weather app but it didn't work either.
Sent using iCafe app
5,580
Try a hard reset. If that doesn't work, reset all settings.
Smarty2600
Apr 23, 2011
344
11
I already held down the power and home button until the Apple logo and that didn't work, that's a hard reset right? What settings are erased after I reset all settings?
Docd
Oct 16, 2011
651
66
Just reset location settings no need to reset all.
Grayburn
Sep 23, 2010
115
14
London, UK
Why don't you turn off the location settings for Weather and set up your current city manually?
Smarty2600
Apr 23, 2011
344
11
Thanks for the suggestion, I just hate it when something is broken because I'm a bit of a perfectionist. And I may end up doing what you suggested if I can't get it to work.
Grayburn
Sep 23, 2010
115
14
London, UK
I'm the same mate, somethings wind me right up.
