Incorrect Weather Location?
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Mine was Incorrect first couple of times I looked but it fixed itself. It also goes off of location services which at times are off. Check it next time u move locations and see what it says.
coop1701
Jun 30, 2007
899
114
43
It seems to correct itself, but only after I open the weather icon. As soon as I do and go back, then it's correct and will be until a little while later.
hplbiking
Oct 1, 2011
29
My problem is not gps related. I have several cities saved and a few of them do not update. They are three days behind. I have closed the app and re booted the phone but no luck
jtsarby
Jun 28, 2009
I live in West Tennessee and my weather and map shows me in Yerevan, Armenia. This only happens when I am at home. My wife's 4 does the same. I have the 4s. This started happening when I upgraded to 5.0.
David Mclachlan
Feb 5, 2012
If you go into your weather app and press the small i at the bottom right of the screen you can toggle show local weather. This seems to be set to off by default with ios5.0.1 update for whatever reason. Hope this helps.
