installed apps, now how do i scroll through them?
Nov 24, 2007
319
hi, i just got the installer. uploaded a couple apps, but as i add more apps(along with more icons) my other applications icons disappear .. how do i fix this? is there a way to scroll up & down in the home screen ? surely i can have more than " 2 " 3rd party applications please help , THX U :p
Gray
Aug 19, 2007
41
you just need to install summerboard. That should fix your problem
Gray
Aug 19, 2007
41
what do you mean? You just need to install the summerboard application to enable scrolling.
gcvt
Jun 21, 2007
1,029
San Francisco
I do see Summerboard 3.0b1 and Summerboard "Old" (2.11). I'm using 3.0b1 and it works perfectly.
