installer and AT&T
alittle0
Sep 9, 2007
Hi-
I apologize if this has been covered, but I couldn't find it.
I have AT&T and I'm fine with it. I had installer on my iPhone, but then upgraded to 1.1.1 without reading any of the warnings so I am back to basics.
Do I need to jailbreak (via www.jailbreakme.com ) in order to get installer back on my phone? I'm find with AT&T, so actually jailbreaking isn't something I want. I just want installer and the 3rd party apps.
Thanks for any help.
Stevonw
Sep 14, 2007
560
UK
So u didn't take the steps before upgrading to v1.1.1 to jailbreak?
Stevonw
Sep 14, 2007
560
UK
So you are currently updated to v1.1.1, sitting with it activated and nothing more?
alittle0
Sep 9, 2007
yep. i'm back to basics (black screen with iTunes music store app) since i upgraded to 1.1.1 a while back.
alittle0
Sep 9, 2007
Hi-
I think I figured it out. I think I've been confusing Jailbreaking with Unlocking. Jailbreaking= 3rd party apps, but not necessarily another network. Unlocking = another network besides ATT.
termleech
Sep 7, 2007
1,154
McPherson, KS
That's correct. I would actually recommend to do a restore to the 1.1.1 firmware and then go to jailbreakme.com in safari and jailbreak the phone. When you upgrade the programs are still there but some aren't compatible with 1.1.1 that were with 1.0.2 (summerboard being a big one). It's just easier to start the jailbreaking from a clean slate.
alittle0
Sep 9, 2007
ok. so, let me just recap (and thanks for the help, by the way). restore my phone, jailbreak it, then once it has been jailbroken, sync my phone again to put back all of my songs, contacts, etc.. Is that right?
Thanks.
termleech
Sep 7, 2007
1,154
McPherson, KS
Almost right. After you restore your iPhone to the 1.1.1 firmware iTunes will automatically put your music, contacts and calendar back on. Then you can jailbreak it.
