Installer Help (categories)
Jun 24, 2008
So i have this problem with my installer, everytime i add a source(most of the time) it will refresh and everything and it will show up under sources in its own category, but when i click on "install" its own category never shows up, for example "community sources" i know for a fact when you click on install there should be a category saying Community Sources, same for Big Boss Apps, its not their either, or any other sources i add, only way to find the apps i need from those sources is to go to all packages and its sort of difficult for me. It worked before, but my installer crashed couple of days go and it would keep sending me back to the home screen so i decided to start all over and delete all the sources i have, using SSH i deleted all these RemotePackges.plist Local.Packages PList etc etc i deleted all of them, but then i added the same sources back in, but they just wont show up in their own category, any ideas guys? thanks
Cusca
Apr 27, 2008
320
ROMANIA
www.cusca.3dk.org
community sources don`t have their own category they get mixed in all the categories same goes for big boss, only some sources get their own category
Jun 24, 2008
That's really weird because before I deleted all my packages using ash, community sources and big boss apps had there own category as well as some other sources but not anymore, is there a way to get them to their own category ?
Jun 24, 2008
hmm I'm not sure all I remember is having them as there own category, even when I go to sources and click on a source it will have a specific category with its own name. So there's no way to make my own categories with the sources I want? Its aloe easier rather then goingto all packages in my opinion.
Cusca
Apr 27, 2008
320
ROMANIA
www.cusca.3dk.org
you can`t make your own categories, but you have the search option which makes things a lot easyer plus every app is in the categori is should be, even it the bigboss apps are not in a bigboss category, for example if there is a audio app from bigboss you will find it in the multimedia category and so on
