Installer messed up my phone...
Classick
Nov 21, 2007
223
I jailbroke my iPhone a few days ago, and I installed Subsystem and Volume Boost 1.1.4, then my iPhone turned off and wouldn't turn on. Once I got it to turn on, it stayed on a loading home screen. I held the power and home buttons and got it to work that way, and now I can't hear anything, and everytime I answer a call it's automatically in speakerphone, which doesn't work either.
I'm restoring it right now.. What happened?
depthnerd
Feb 16, 2008
1,280
I don't know but you could've SSH'd when it was at the Apple screen and deleted the apps you installed.
aaronsiphone
Dec 28, 2007
297
try uninstalling subsystem and volume oost of go to general >setting> restore all works a reat for most of us! sometimes apps conflict with each other and just screw up your phone, sound always goes on mne, im used to it, just uninstall the last app i installed. as for the loading screen had that also when i downloaded font changed, really screwed my phone up, wouldn't switch on, took me about a day to get the thing back! but jailbroke straight after restored
Classick
Nov 21, 2007
223
The restore worked fine.
So when I jail break it again, should I reinstall Subsystem, and install SSH?
And what are those two anyways?
