Installer Remove how?
jfagundo
Sep 14, 2007
31
Hi Everyone,
How can I remove Installer from a jailbroken phone? I only wish to use Cydia as preference. Installer has been buggy.
28,365
5,507
I don't think you can remove it without restoring the phone. Just try to ignore it and let it take up space. I've never even opened it because it's well known that it's buggy.
Supposedly, there is a way to stop it from installing when you are Jailbreaking. But that wasn't an option last time I JB with QuickPWN. Maybe that's just with Pwnage Tool?
jfagundo
Sep 14, 2007
31
Actually yes, it gives you the option to check/uncheck for install while jailbraking with QuickPWN. I didn't install it on my other iPhone when I jailbroke it.
There must be a way without totally restoring but if not, oh well, I'll let it sit taking up space.
:confused:
