Installer taking long time to bring up sources
Mar 4, 2008
i was going onto installer and it was taking forever to check sources, so i held down the top button. now whenever i turn it on it says:
singleuser boot -- fsck not done
root device is mounted read-only
if you want to make modifications to file:
/sbin/fsck -fy
/sbin/mount -uw /
if you wish to boot the system:
exit
mar 4 21:43:57 launch[18]: can't exec /bin/sh for single user: no such file or directory
does anyone know what to do? i plug it into my computer and it doesn't show up on iTunes.:(
Y-Less
Feb 28, 2008
149
Netherlands, The
If im correct then your iPod Touch is broken, Please take the follow actions:
1. Put your device in restore mode (First press home and don't release the button and olso press the power button, Don't release the botton's until the device shows a "Connect to iTunes" picture.
2. Open iTunes and restore your device to the latest firmware, currently 1.1.4.
3. Jailbreak your device if you like and want too.
iStealth
Nov 5, 2007
421
Yes force restore as mentioned above /\/\/\ then rejailbreak
