Installer's icon missing on iPhone
Sep 14, 2007
I jailbroke and activated my iPhone and it works fine until I try to install the installer on it, after tons of time install and uninstall using iBrickr v0.8, it still not shows on my iPhone but can show, each time, on iBrickr. Other apps works just fine.
Who can tell me what is the reason and how to solve it?
Sep 14, 2007
thanks first, but did that several times, still nothing there :(
420greg
Jun 26, 2007
845
Orlando, Florida
How many apps have you installed? Do you have summerboard?
Is the installer Icon just to low on the main menu to see it?
Sep 14, 2007
it's the first app I try to install, so definitely not the space issue
Sep 14, 2007
and I even try to redo the jailbreak and activate from scratch to get it back, but still in vain
Sep 14, 2007
the weird thing is that all the reactiona are normal, like show up on my iBrickr's list, and soft reboot of my iPhone. So, I believe it's installed yet, but just no access (Installer's icon) to use it
saplingg
Oct 22, 2007
17
If you have iBrickr installed, you can delete your unwanted apps to bring Installer to the front. Alternatively, you can install a program such as Mobile Finder or Summerboard which will give you access to the icon.
Google iBrickr if you don't have it.
