Installing Nintendo Emulator & Roms Guide
C
cadsii
Guest
This tutorial is written using an iPhone 3G running 2.0.2 firmware, jailbroken. You can use these steps to install NES on any jailbroken iPhone running firmware 2.0 or above.
We will break this down to 2 parts, installing the emulator and then uploading the roms.
End result should look like this :)
Lets start with the phone.
Step 1.
Fire up cydia installer from the phone.
Step 2.
Select featured packages.
Step 2.
Select NES listed under free applications.
Step 4.
Select install on the top right corner.
Step 5.
C
cadsii
Guest
i cant do more then 6 images per post...
full guide here
Full guide and comments can be found here.
rivet
Jul 19, 2008
Great guide
Thanks very much for the guide, it helps me get my NES games working on iPhone. However, I am having difficulties finding rom files. I download many rom files but most of them won't work, only *.NES files works.
I am wondering do all the NES emulator works the same way? (recognize same Rom files?). Is SNES roms compatible with rom emulator downloaded directly from Cydia? Any one have public or secret rom files downloading links, please PM me. Thanks very much.:laugh2:
rivet
Jul 19, 2008
ops.
Did not noticed that OP is banned :eek:. Anyway, thx.
RyansTitan05
Aug 21, 2008
392
54
where do i find the games to put on my phone?
D-Wade
Aug 26, 2008
69
Singapore
google it =)
i have installed punch out and mario bros
working fine =p
