Interesting observation (signal strength)
jtsarby
Jun 28, 2009
I don't get the best reception on my iPhone at home. At best I get 2 bars and mostly 1 bar. I purchased the iPhone dock this weekend and noticed that when docked I now have 4 bars! Why would the dock result in better reception?
6,682
49
Most likely it has nothing to do with the dock. Over the past few weeks, I have watched my signal strength improve drastically in areas I was lucky to get 1 -2 bars edge. Now I show 3-4 bars 3G. It's part of AT&T's network update.
jtsarby
Jun 28, 2009
I hope you are correct but if I take it off the dock it instantly drops 2 bars. As I sit here right now I actually have a full signal. I have never had that before. Either way it is good.
stevetim
Jul 20, 2007
606
When you say dock, is it charging?
Only thing that would come to mind, is your battery isn't operating at full voltage to send/receive a better tower signal? But when plugged into a charger, the A/C gives it a power boost?
Tinman
4,334
183
Aridzona
This is believable. The dock could simply be working as an extension of the antenna (not intentionally). The location and properties of items near an antenna can and do affect its performance.
So let's say that for some reason the dock is acting like an antenna of sorts--again, not intentionally but due to its positioning, wires connected to it, etc. So it receives this RF energy but has no receiver with which to use it. So that energy is re-released (scatter) and then captured by the nearby iPhone antenna, ending up with an iPhone with better reception.
Or the whole thing could be a figment in the mind of the OP. ;) (JK!)
Mike
